22RE Valve train noise
This 1990 22RE that I've had for the last 4 months is the smoothest running one I've ever owned with only 101K miles. The only issue is that it seems on a warm start.(after the truck has been driven and sat for 10-15 minutes) I can hear some valve chatter for a second or two once in a while. It sounds like it takes the oil a second or two to get to the top. I am wondering if this is normal for a 22re as every other one I have owned has been ten times louder and I probably couldn't have heard the noise if I tried. On a cold start you can't hear it it's only occasionally on a warm start. Should I switch to 10W40 from my usual 10W30 or maybe try a 5W30 synthetic? I'm using 10W30 valvoline right now and it uses no oil between changes.
Did you replace your timing gear like you were talking about a while back? Could be some broken guides. Those are notorious on 22res for causing loud start ups. It may be worth pulling the valve cover and having a look with a flashlight. Did this noise just recently start? If your guides are ok I would say adjust the valves, bolt it back together and go wheeling!
Haven't done that yet and it's cold now, but it doesn't sound like a timing chain. I guess I should pull the cover off when we get a warmer day here.
