22re Turbo Issues
Old 05-20-2013, 10:04 AM
DALTON09's Avatar
22re Turbo Issues
I have a 89 4x4 truck came from the factory as a 22re, later someone installed a factory turbo set up, guy i bought it from claims he drove it as a dd an four wheeled it once a brought it home pressue washed it came bac few days later it ran ruff at first then died, from then on it would start right up (running smooth) run for 3-5 seconds an die an will do so over & over.
( this is how i bought it for $800), needing some help on dignosing the issue
things ive tried:
-holding flap in air box open with fingers
-crossing fuel pump +b -fp
-checked fuel lines from pump (pumping gas)
-different air box lid
Old 05-26-2013, 08:28 PM
edeslaur's Avatar
Change the title to the problem, you'll get more hits. This is a not a turbo issue.
Old 05-27-2013, 02:58 AM
wyoming9's Avatar
Red face
Have you checked the fuel pressure with a gauge??
Pumping does not mean it is correct
How much gas is in the tank??
Are your plugs wet
have you checked the injectors are firing ??
Then you really don`t know if the person you bought it from is being up front
This issue might have nothing to do with it being washed.
Mouse nest in the air intake system?? the intake manifold i got a truck that way for free.
Back to the basics Spark fuel air compression
Go from there.
Old 05-27-2013, 03:48 AM
maachine's Avatar
fuel filter?
Old 05-27-2013, 09:31 AM
INFINITY's Avatar
sounds like a cracked air intake hose after the afm and before the turbo. pictures of the engine bay to see how everything is set up would help. also ignitor might be toast or the ground in there is corroded?
start checking for fuel flow, ignition, wiring connectors, dist cap, air plumbing, cold start injector (might be running off of the cold start inj then dieing when the timing temp switch turns off) listen/feel the injectors to see if they are clicking/opening.
the problem could be worse like the one i am having with my 7mgte.....
Old 01-26-2015, 07:19 AM
terik's Avatar
22re turbo issue
hello everyone...i also have a turbo question. first time 4runner owner. i have a 1987 4runner with a 22re turbo automatic. it seems to run/pull better when with 1/3 throttle than 3/4 throttle....ie less boost. it has a t3 turbo apparently. the turbo has an exhaust leak. i was told it was the gasket. would that be the problem or something else. ty for any help
Old 01-26-2015, 08:55 AM
MAINETOY's Avatar
Turbo issues
I would check the rubber connectors on the air intake to make sure they are not cracked,that is a very common problem and would check that over very closely first and foremost.And make sure all clamps on the connections are tight.
MO transplant
04-23-2023 11:58 AM
mskalmus
05-28-2017 07:51 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
tobylab
07-12-2015 12:53 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 22re Turbo Issues
