22re truck idling weird
22re truck idling weird, with video
hey guys im having trouble with my truck its idling weird and its running lean.
need some help on diagnosing the problem. hers a short video of what it sounds like, sorry its not a good one but its all i could get http://www.youtube.com/watch?v=-Gk-8mkW8L8
about what RPM is that?
only reason I ask is...
[YOUTUBE]http://www.youtube.com/watch?v=QFUoC9M3JLc[/YOUTUBE]
[YOUTUBE]http://www.youtube.com/watch?v=UdUdBz-v0uo[/YOUTUBE]
and I found a floopy timing chain due to an exploded driver's side guide and a shot tensioner
ive don it. it hasn't fixed the problem, it had a exhaust leak the same time i took the video. i fixed it and it still sounds the same. dont know what else to do, it just sounds so bad now.
http://www.youtube.com/watch?v=ycAhKsLg3So. hers what it used to sound like, this video is not mine and its not my truck but it sounded just like it
well it used to sound like that i don't know what happened. it started a few weeks ago.
im just trying to figure out why it sounds like that now. to fix my lean condition im going to try and replace the o2 and see if that helps
Still not sure why you think it's running lean... and not sure why you think a new O2 is going to fix it. If the mixture is far enough out to require an O2 sensor, you'd get a code.
Ya know... knowing there was a code involved would've helped a lot.
check for leaks along the intake duct and PCV system. Fix any exhaust leaks between the head and the O2 sensor.
Reset the ECU and see if the code comes back.
ok well i checked for some more exhaust an intake leaks and i dident find any, i checked the o2 sensor out and found that it had ben hitting the exhaust an had some burnt wires so i took it out, cleaned it and fixed the wires. pulled the efi fuse for 15 sec and reset every thing. well ive drove it around for a day now and no codes so i fixed that problem, but i still have the weird idel. i dont no what to do about it, could it be my msd coil?
alright guys i took the msd coil off and put the stock coil back on and bought new stock wires, spark plugs, and cap. well this did not fix my problem. ive tried spraying carb cleaner along the intake to check for leaks, i haven't found any.,
well earlier i went out side to crank my truck and it just turned over, it would not start so i waited a few secs and tried again still nothing happened so i waited a little longer and tried again and it finally started to fire but it sputterd at first then fired right up. but i noticed it smelled really rich like it wasn't getting spark, but i have a code 25 and that means lean so i dont know what to check, i was thinking it could be my igniter. any help would be appreciated.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
