22re troubles
22re troubles
i just rebuilt my 22re new everything the truck is a 93 it has very low power than what it should, i installed my jumper wire and when at idle no codes than when u bump the gas i get code 51 it will only give that code if it is running, that is the only code, when i bump the gas it quits out untill i let off
You might want to get a meter and test it out. Maybe it's plugged in but fried.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
defrag4
07-31-2015 10:50 AM
