YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 05-08-2007, 02:03 PM   #1 (permalink)
Personal Sales Rating: (0)
22re tps problems
hey guys n girls,
I just put a fresh new 22re engine in my 93' p/u. I had my throttlebody and intake cleaned and the shop i took it to removed th throttle position sensor and put it back on without adjusting it back to specs , causing the engine to surge between 1500 and 3500 RPM, anybody have any idea what the factory specs are? and how to remedy it thanks
907yota is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 05-08-2007, 03:41 PM   #2 (permalink)
zozoka's Avatar
Send a message via Skype™ to zozoka
Hello
Had the same problem with the TPS sensor in V6 3.0
/f116/gap-between-1800-2300-rpm-tps-problem-109638/
I adjusted to the specifications , following 4crawler description, now everything is fine.
You find here :
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Zoli
__________________
1990 4Runner 3.0 ,5.manual , OME susp.kit + 1"BL , 33" Cooper Discoverer S/T on 15x8 Eagle wheels
Truetrac LSD front+rear , 12000 lbs winch
zozoka is offline
Old 05-08-2007, 04:00 PM   #3 (permalink)
Personal Sales Rating: (1)
slacker's Avatar
yikes .. I guess your not taking it back ?
http://personal.utulsa.edu/~nathan-buchanan/93fsm/ is the service manual on line .. check out the specs there , and have fun .
__________________
http://www.toyotafiberglass.com
check out all of our builds in the VENDOR section
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE CURRENT PROJECT
83 Trekker SR5 DONE June 2011
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 05-08-2007, 04:20 PM   #4 (permalink)
Threadstarter [OP]
Right on, i'll try it out, big mahalos fo da info
907yota is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
1990, 22re, 22retps, accociated, idle, issues, position, problems, put, sensor, stalls, surges, symptoms, tacoma, throttle, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
87 22re tps da92ls The Classifieds GraveYard 1 07-17-2007 05:52 PM
Throttle Positioning Sensor TPS 22re brendonv The Classifieds GraveYard 1 07-03-2006 06:51 AM
84 22re TPS help 3cRider 84-85 Trucks & 4Runners 2 06-23-2006 02:31 PM
TPS and timing problems...? Runner 95.5-2004 Tacomas & 96-2002 4Runners 1 10-31-2005 04:31 AM
22re TPS help Tokez420 95.5-2004 Tacomas & 96-2002 4Runners 2 05-30-2004 08:45 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
