22RE ticking problem
Old 05-21-2009, 02:28 PM
dyroot's Avatar
I've looked around before I asked, but I just cant find anyone who had the same problem as I so. My 22re in my 87 yota is ticking, but only around 2000 RPM, any lower it doesnt, and any higher it doesnt. Its not that loud, just a slight ticking. What could this be and is it easily fixed?
Thanks
Old 05-21-2009, 03:03 PM
toyota4x4907's Avatar
Its really difficult to determine without actually hearing it. Could be valves, but they usually tick at lower rpms, could be injectors, but you probably couldnt hear them at 2K rpm. My guess is an exhaust leak. Could be a number of other things. Try to determine where its coming from, ie, bottom, top, driver's side, passenger's side, exhaust, etc.
Old 05-21-2009, 03:08 PM
dyroot's Avatar
I went outside and checked it again, and it sounds like its coming from the bottom somewhere, I cant tell where though. Does this mean exhaust?
Old 05-21-2009, 03:23 PM
Bottom of the engine?
Can you tell if it is more prevalent on either side or the same on both?
Do you have enough oil?
Old 05-21-2009, 03:52 PM
Chutchman's Avatar
I would say valves as just a guess. It wouldn't hurt to adjust your valves anyway. It is really easy if you go buy a nice feeler gauge with an angle in it. While you are in there you can take a peek at the timing chain guides.
On my truck the fuel injectors make a small tick at idle. And I have just a little valve noise at idle as well. Usually by 2000rpm it has smoothed out. I am stumped. Does anyone think it could be bottom-end?
Have you changed your oil recently? I swear my truck made more noise after a recent oil change. I didnt use my normal brand of oil and now I am thinking it had something to do with it.
Old 05-21-2009, 04:16 PM
iamsuperbleeder's Avatar
22re's are noisey egines
if I've ever heard valve chatter on a 22re, it's LOUD... not like a slight tap for some reason... at least from what I've seen, lol.. it's like, there's either no valve train noise, or it's OMG THIS THING'S RUNNING?!?! kinda loud
the injector's, they're crazy loud too for whatever reason, on some vehicles more so than others. I never knew mine were so loud untill I fixed my exhaust leak
exhaust leaks are pretty common too and can cause the same ticking noise; mostly around the point where the manifold and the down-pipe meet. there's 2 fiber doughnut gaskets there that I went through 2 sets a month untill I replaced the setup with a header
Old 05-21-2009, 06:46 PM
dyroot's Avatar
Alright thanks, Ill get out there tommorow and try to pinpoint it better for you guys. Thanks for all your guys help so far
jbv808
08-06-2021 04:47 PM
steve miller
10-10-2015 01:40 AM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: 22RE ticking problem
