22re throttle surge/pulsating
This just started today. Last night I replaced vacuum hoses 1 by 1 so they are all correct. I also replaced pcv valve and grommet. I didn't notice this last night. When I started it up today it started doing this. Idles perfectly fine. One does this when giving it throttle
UPDATE: only does this after warm. Does not do it when cold
Video-
Video-
Yes I tried old pcv and put all the old hoses back in yesterday. Problem still there. I think the problem is elsewhere just a coincidence it seems to have started after replacing hoses..
Yeah, that stinks. I always think it's something I did. Might check the coil, see what the ohms are. Or fuel pump and filter. Heck, I might even pull the negative battery cable off for awhile.
Thanks will check those. And negative cable has been off all day. I've got tonight and all day tomorrow to figure it out...
I have a hard time following the quote "if it ain't broke don't fix it." Lol seems like every time I try to do a little preventative maintenance a problem occurs!!
Problem solved, I was wrong. Somehow I did manage to cross up a vacuum line at throttle body. All new hoses in and running like a champ again.
Stanz my idle is great! No bumps or anything. I solved this issue a while back it ended up being that after I changed vacuum lines I crossed two up..
Now I'm dealing with a sticking throttle!! Can't figure it out
montanatruck
02-26-2017 07:07 AM
