22RE Throttle Position Sensor worn out. what now?
Old 03-15-2009, 07:10 PM
cjpearson.207.'s Avatar
Cool 22RE Throttle Position Sensor worn out. what now?
hi everyone. looking for someone who has experience with the TPS sensor on a 22re. My Throttle Position Sensor is probably chock full of crud. The sensor is from a different year from the current engine (a 1990). should I search for another sensor through junk yards till i find one that works or it worth it to get something new? any updated new sensor that is a better than the original linear type sensor? Is one replacement sensor much better than others, if so where can I find one? etc. I know as much about this subject as I have read on this link:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
I want to get my sweet 94 yota optimized for fuel efficiency and power. clearly right now, I need to solve the problem of a worn out TPS. I appreciate any interest in sharing your knowledge on the subject!
Old 03-15-2009, 07:39 PM
abecedarian's Avatar
What makes you think the TPS is causing a problem? You've tested it per 4Crawler's directions and it fails?
Old 03-17-2009, 08:41 AM
tps check
I still need to do the tests with the feeler gauge and ohmmeter. I recently cleaned the intake with seafoam through the egr vacuum line and I suspect that could have wicked contaminant into the pc internals on the sensor. I will in the mean time investigate further with the resistance tests.
Old 03-17-2009, 02:35 PM
only way the seafoam would've got onto the sensor from a vacuum hose is if the throttle shaft bushing is worn. so, not likely the cause of your problem.
Old 03-17-2009, 04:50 PM
myyota's Avatar
You can get a new TPS from Rock Auto for about 85-90 bucks, i just bought one for my 4Runner.
Old 03-17-2009, 05:36 PM
Got a TPS for my 88 from Autozone 2 years ago for $79, and they had it on the shelf.
But your mileage may vary (no pun intended).
Old 03-17-2009, 06:12 PM
raydouble's Avatar
Bout $80 from 1sttoyotaparts.com for OEM, if it needs to be replaced.
Old 03-17-2009, 07:27 PM
75k5toy's Avatar
Tps
Well. if you r sure the tps is your problem, go get a new one. I'm a junk yard dog myself but when I need something related to the to the fuel/smog stuff, I stay away from the bone yards. after all maybe 90% of the cars r there because they fail the smog thing.
Old 03-18-2009, 11:48 AM
SoCalR6's Avatar
Thanks for the "1st" link. I always buy from 1stVW parts. Did not know there was an online brick and mortar dealer for Toyota.
smthwsn357
12-04-2023 02:08 AM
06-01-2021 01:51 PM
Doug4320
03-24-2018 10:11 PM
smiley52
07-11-2015 05:16 AM
garagespace
07-09-2015 08:37 AM
Quick Reply: 22RE Throttle Position Sensor worn out. what now?
