22RE test connector-make it yourself
Old 04-06-2012, 08:24 PM
blackdog314's Avatar
This might have been covered already. But if anybody is having trouble finding something to jump the test connector with just grab a piece of coat hanger or bailing wire. Cut to length, 5 inches or so, and use a hammer to flatten the end enough to fit. With the thicker wire it is easier to keep track (mine is hanging in my engine compartment) of than a paper clip and it works just as well.
Cheers
Old 04-06-2012, 09:00 PM
Turd Furgeson's Avatar
I just loop a piece of whatever wire I have laying around
Old 04-06-2012, 09:07 PM
BMcEL's Avatar
I have a paper clip and/or piece of wire in my ash tray at all times.
Old 04-06-2012, 09:17 PM
I have a problem with losing things and now it is hanging 6 inches away problem solved...until I lose that too.http://images.ibsrv.net/ibsrv/res/sr...s/headbang.gif
Old 04-06-2012, 11:37 PM
fork's Avatar
an appropriately sized one of these is what i carry
Old 04-07-2012, 12:44 AM
Utah4Runner86's Avatar
I keep my paperclip wrapped around the wires on the test connector.
Old 04-07-2012, 03:31 AM
Bassmastry101's Avatar
I took an idea from 4crawler. I made up a switch panel in my engine bay and used flat connectors to wire it up. Also have another switch for work lights mounted under the hood.
Old 04-07-2012, 04:05 AM
That's a cool idea! You should put that switch under your dashboard, tho, read your codes without having to pop your hood...
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 22RE test connector-make it yourself
