22re starting problem
i have a 86 4runner with a newly rebuild 22re. about a week ago it just stopped turning on. it gets no power when i turn the key forward. so i had the battery checked and its fine.heres the strange thing, if i jump it the engine cranks right up no problems.is this a fuse problem,or some sort of wire connection? any ideas guys?
It may be the starter relay. Also check your battery and all ground/electrical connections for any signs of corrosion. You may have a rusty bolt that could cause the connection to be too weak to generate your cranking power.
Check out this post https://www.yotatech.com/forums/f116.../#post52171407
and this one
https://www.yotatech.com/forums/f116.../#post52166219
to zero in on where the problem is.
and this one
jennygirl
11-17-2015 11:24 AM
