22re and SAS?
Old 05-13-2012, 09:50 PM
dstout49's Avatar
Question 22re and SAS?
92 runner, 22re(new), manual trans, basically stock.
here is the idea, I want to do a sas and a lift. I was thinking about ordering the sas kit and the rear leaf kit from sky-manufacturing. I came across a 85 toyota (or that is what i was told) front axle(wondering if this would work). also what kind of gear ratio should I use if I want to get a 6'' lift and 33''-35''. so far I have done all the work to it myself. this SAS idea is all new to me, I know very little about axle rebuilds and gear ratio.
so the basic questions, is a 22re strong enough for a solid front axle?
what is a recommended gear ratio for over-sized (33"-35") tires?
will the 85 toyota front axle work?
Old 05-13-2012, 10:03 PM
Discombobulated's Avatar
Search is your friend on this one, and welcome
Old 05-14-2012, 01:39 AM
wii_tarded's Avatar
https://www.yotatech.com/forums/f152/
have a look at this section. should answer all your questions.
Old 05-14-2012, 04:34 AM
waskillywabbit's Avatar
22RE will be fine if in good shape.
Any solid front axle from mini truck will work, 81-85.
33" tires will be too small. Minimum 35" tires and 5.29s
Old 05-14-2012, 10:37 AM
dstout49's Avatar
thank you waskillywabbit. thats what i was looking for.
Flying91
45
04-11-2024 04:39 PM
Backcountry411
Diesel Swaps
07-29-2015 01:33 PM
Backcountry411
07-24-2015 08:06 AM
boogiewoogie
07-24-2015 05:10 AM
Quick Reply: 22re and SAS?
