22re Runs rough sometimes
Old 01-19-2012, 05:59 AM
1994toyota's Avatar
Hello, I have a question for everybody out there. I have a 94 toyota pickup 22re and it idles rough. It does it hot or cold when I am just sitting there idling. It wont die but it just seems like it idles to low. It seems to only do it sometimes. Other days it seems to do fine. What should I check for? Thanks Brad
Old 01-19-2012, 07:05 AM
sixstringslut's Avatar
Good to see a fellow Ohioan on here.
After usual plugs/wires, cap/rotor check. Check TPS, or possibly try better gas for few tanks. But, you probably did all this already.
Old 01-19-2012, 08:46 AM
Sensei's Avatar
Check the air intake plumbing for cracks. Any induced air after the AFM will cause idle issues. Also check for vacuum leaks. Since it seems to be an intermittent problem, check all hoses and electrical connections. Could also be a dirty injector that's leaking.
Check the basics first.
Old 01-19-2012, 09:18 AM
1994toyota's Avatar
I replaced the cap and rotor, and plugs, but not the wires yet. I should replace the vac lines as they are looking old and dry. Is there a kit for the vacuum lines or do you just buy vac. line by the foot? I do not think it anything to major. Also the belts squeel. Should I pull them off and then start it, or just pull them off and check all the pulleys? Thanks
Colington
03-08-2020 09:51 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
bryan34w
07-06-2015 05:53 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 22re Runs rough sometimes
