22re Running Too Cold- T-Stat?
Old 11-20-2011, 09:03 AM
turbowhine's Avatar
My '91 22re starts and runs great, but it won't come up to operating temp. The heater blows warm air- maybe not warm enough, and it is getting snowy here in Spokane. But even after 45 mins of driving stop and go, it's still running the cold high idle at stop lights and the temp guage is only slightly above 'C'. Is there anything simple to check before I rip into the cooling system to change the thermostat? Also, if I do need to check the t-stat, is it possible to do it without draining all of the coolant. I'm not at my home garage so I have a very limited shop/workspace/tools. Thanks.
Old 11-20-2011, 10:18 AM
diablo's Avatar
I have the same problem with a 77 corolla, Im going to put a new t-stat in. It will never get above the first mark on the gauge. T-stats are cheap.
Old 11-20-2011, 10:28 AM
jkent's Avatar
I have the same problem too after putting in a new radiator and clutch fan...I got a new thermostat from Toyota and it ran too hot?? went back to the old.
Old 11-20-2011, 02:00 PM
snobdds's Avatar
Go to the dealer and get an OEM one. The dual valve is best. Just search temp gage overshoot and you will get the part number.
The stock temp is 88*C which is about 193* F for a 22RE
The 22R is set to open at a lower tempature, (can't remember off hand but it's like 180*) and many parts houses don't know the difference between the two motors and hand them out in mistake. This causes a lot of 22RE's that run too cold.
Old 11-20-2011, 09:53 PM
4wd4fun's Avatar
mine is blowing hot air within about 5 miles driving and at that time the temp needle is just moving above the white line above cold on the gauge but it may take longer if I have the recirculation at 1/2 open and even longer if it's at full open.
but if the thermostat is stuck open for whatever reason, most of the coolant will go through the radiator and just a little will go through the heater so you won't get any real hot air.
Old 11-21-2011, 09:23 AM
turbowhine's Avatar
I haven't even tried running the recirculator. That's exactly the type of simple thing I need to try before I start swapping out good parts.
Old 11-21-2011, 10:46 PM
Camo2294's Avatar
My 86 22re has new Tstat and temp sensor and only runs a quarter inch above cold line, only time she heats up more than that is when heaters on, it will come up to a little under half then
Old 11-22-2011, 02:21 AM
91muddog's Avatar
same issue just started with mine. putting a new tstat in tomorrow, ill let you know how it goes!
Old 11-22-2011, 02:35 AM
mldave's Avatar
My 86 22 RE takes a few miles of town driving to reach halfway,then drops and stays between 1/8th-1/4 when the t-stat opens.Up a long steep grade it'll go to half and drop back again on the flats.
Old 11-25-2011, 01:25 PM
turbowhine's Avatar
It was the thermostat. A rubber seal around the mechanism broke down, exposing several small holes letting coolant flow all the time. It was a really easy job to swap out. I drained about 1/2 gallon of coolant from the bottom of the radiator. The t-stat housing bolts weren't jammed, and the hoses were all good. Started up and ran great.
Colington
03-08-2020 09:51 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
Yotoder865
07-09-2015 07:51 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 22re Running Too Cold- T-Stat?
