22RE rebuilding ?
22RE rebuilding ?
can some one tell me how to or tell me a good link to rebuiling the 22RE. I have done the top half plenty of times but never attempted the bottom end also where is the best place to order Toy eng. rebuild kit's & parts something like a "Dennis Kirk" . Also if I decide my piston/ring's are ok but wanna replace my bearings can I just put STD. bearing's back in? Any help would be greatly hepfull.
As for a guide I am trying to get my hands on a Toyota rebuild guide from a friend who is a Toymaster tech I think that would be the best guide plus his personal knowledge.
My 2 cents is that you either do the bottom end or don't. By this I mean piston, rings crank and rod bearings. If you are then I would have the crank reground and undersized bearings put in. The bottom ends in these engines are very good.
If you don't want to do this and just freshen it up then pull the pistons, hone and put new rings in. If the bottom end is not knocking then I would leave it alone. Else do the whole thing.
Thank's for the info.I have a couple of Haynes Man. & spec. Toy repair man. but cant seem to find info on what size bearings & ect. to order as in STD.,.20-.30 ect. is that were a plasti-gauge comes in handy
MMA_Alex
25
04-18-2017 05:07 AM
shadowbirdie
07-21-2015 10:38 PM
