22re rebuild. exhaust suggestions??
hello im new to the tread. i own a 1992 toyota pickup 4x4 with a 22re. i blow my engine and i am now rebuilding one. it is bored 20 over and all new piston and machine work, i have a rebuilt head (port and polished) adn the engnbldr 268 cam . its got cold air intake with a AFM tweek. i was wondering what a good exhaust set up would be with a stock manifold (which is great) and no cat. pipe size and muffler suggestions.... cheaper but not to cheap... cant be to expensive i am in school adn have very little income.. a
Also any other mods you would suggest for me to do for a little gain in power for highway crusing and off roading.
Thanks
Thanks
I dont know about a built motor but 2 1/4". Seems to be one of the more popular exhaust diameter. Propper back pressure seems to be very important. I run a magnaflow muffler and like the way it sounds. But I also have a cat on mine. I still want to get my headder put on.
I am interested to see all the suggestions
so 2 1/4 is my best bet. should i run it all the way back our side pipe. also what would be a good muffler chioce? i have a thrush trubo...what do they sound like on a 22re with no cat?
I run 2 1/4 magnaflow 40 on my 22re with the L.C.E. pro street head and 261 cam from enginbldr seems to be a very nice match and has a nice sound at idle almost sounds like a v8
You're gonna want to have your pipe bigger, because with more air and fuel coming into the engine, you're gonna need to get the exhaust out faster. 2 1/4 or 2 1/2 should do the trick without getting in the way. cherry bomb turbo and vortex sound sick too. my yota was straight piped with a boom tube on the back, it sounded great, and attracted some -wanted- attention. hehehe
Pro-Trux did some testing with the muffler shop I had some work done...
He said for a stock to mild motor best set up was 2.5 then a 2 1/4 at the tip worked out the best..
