22re problems
22re problems
i need help.. i was working on my 87 22re and it was cranking and turning over fine but wont idol (shuts off after about 5 seconds) and i sprayed some starting fluid in it and it ran fine and kept it running for about 10 secs with starting fluid and it shut off and now it wont crank and nothing comes on, i checked all the fuses and they are good so what elese could it be? any ideas will be appreciated
alternator maybe. if it drained the battery there may not have been enough juice to power the computer and fuel injection.
it starts by gas after a few cranks but wont run for long but easier with starting fluid when it did start and it kept running as long as i sprayed it but would run and shut off after a few seconds of not spraying
Your first problem sounds like a bad VAFM or failing COR. Whilst cranking (key to start) the fuel pump receives its power from the COR triggered by the ignition switch. After cranking is finished (key returned to start) the fuel pump receives power from the COR triggered by the VAFM. If the VAFM is failing or the VAFM side of the dual coil COR is failing the fuel pump will shut off after cranking and your engine will splutter to a stop.
But now It wont crank (starter motor does not engage) and nothing comes on (not sure exactly what you mean, but I will assume you have no power anywhere) then you have bigger issues. If you have lost power to everything, start at the bottom of the tree...battery > battery post connections > fusabile link > fuse box etc etc....
ok i have to look in to the vafm and cor but yes no power anywhere, and ill have to look and check the fuseabile links, but maybe a bad ignition switch?
Does your horn or hazards work? They both receive constant 12V independent of the ignition switch. If you dont have power there it has to be battery, or fuse box connection issues. Cleaning your terminals is always a good start
Hey Guys, new to the forum and trying to search for similar problems before starting new threads. One of these answers might just be what I am looking for. Not only new to Yota Tech, but new to Toyota also. I have a 85 22re and the only way I can get it to run is to stick a hot wire straight from the battery to the fuel pump. Runs great that way, but if I plug the factory wire back in it will only run for a second and then shut off. I can hear the fuel pump Kick on when turning the key, so something is telling it to shut off after starting. would that be the COR and VAFM mentioned above? And what/where are those? Thanks.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
shuts off after about 5 seconds is almost always AFM not plugged in...
happens to ppl all the time, I know I've done it...
steve miller
10-10-2015 01:40 AM
Odin
07-15-2015 09:28 PM
