22re overheating
Old 11-19-2009, 04:47 PM
redneckandy's Avatar
22re overheating
new motor, the timing is correct now at 5 degrees btdc. grandpa says the coolant lines are airlocked. what do yall think?
Old 11-19-2009, 05:06 PM
myyota's Avatar
What the condition of the radiator ?, have you ever had it checked out by a radiator shop ?, when you replaced the engine did you install a new thermostat ?. If all of that is good then leave the radiator cap off and let the engine run for a while until the thermostat opens, also set the heater control to hot and the air should work its way out.
Old 11-19-2009, 05:13 PM
92 TOY's Avatar
is there any value / contraindication in putting the front of the vehicle on ramps while running to burp the air out?
just a thought.......
Old 11-19-2009, 05:17 PM
TOYOTA 1's Avatar
^ yes actually that works well!
Old 11-19-2009, 05:19 PM
92 TOY's Avatar
Then "YAY ME".......
Old 11-19-2009, 05:59 PM
radiator and thermostat are both brand new. and hahaha ill give that a try. i think we may have gotten it fixed it suckin down coolant now and it quit overheating. and actually i dont think it was overheating bad, the temp guage seems to not be workin properly :/
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Logz808
07-26-2015 07:09 AM
Jeffreynmandy
07-18-2015 08:26 AM
the1998sr5
07-16-2015 06:20 AM
Quick Reply: 22re overheating
