22RE- new oil pump install.
Installing a new oil pump on a 22re, and my manual says to lubricate the pump gears, propably just in motor oil, but is there anything wrong with using assembly lube, just being that it stays put better and won't drip?
Also, I need to know the bolt sizes for each hole... and if there's a really thorough re-assembly thread on here, I'd like to know where I can find it. Without enough concern for putting the motor back together, I yanked it out and took it to the machine shop. Now I find myself with a few different bolts for certain assemblies, and not sure what goes where. Thanks guys!
i prefer the secret trick of packing the pump gears with vas-o-line
https://www.yotatech.com/forums/f116...rebuild-96391/
09-04-2015 09:27 AM
