22re mods
22re mods
ok guys dont get to rough with me. I am getting ready to go through my 88 truck it has a 22 re and am curious about some not to expensive performance mods. I am just goin to be turnin 33`s, is there any sugs.
Header- $250-500, maybe 10bhp
Cam- $150 + head gasket replacement- moves torque peak around
'82 Supra AFM- $50- 750, ?
cleaning- free, depends
flywheel mass- $200?, gives more low end torque BUT hampers reving
Porting and polishing ?, ?
I'd say pull that big @$$ bail of hay out of the back. I bet you see an instant increase in felt power.......
There really isn't a lot that can be done with these motors and I think Matt covered all the good ones.
1 Post
Lemme add to it..
You can nickel and dime this thing to death and it wont get any better after all this is done, you might get 140-150 HP out of it doing all this, if you want power do a Lexus V8 swap, or Turbo it.. Your call.. Its a FORKLIFT engine, they aren't porche's..
Header- 300-500$ NWOR makes a good one..
Cam + head gasket replacement. 100-150$ Enginebuilder makes good cams..
'82 Supra AFM- 50-75$ Junkyard..
Cleaning-Degrease engine, clean throttle body, seafoam. 10$
Heavy Flywheel & Stage I Centerforce Clutch- 300$?, More low end torque but slows revving.
Porting and polishing Free-100$
ACCEL Wires + NGK Plugs 50$
Distrubutor Recurve Kit 20$
Free Flow Exhaust 100$ if DIY, Prolly 300$ for a shop to do it.
Milled Head 100$
Milled Head 100$
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
icentropy
07-11-2015 07:21 AM
