22re Missing Sometimes?
Old 09-22-2011, 01:35 PM
A2theK's Avatar
Just bought the truck about a month ago which had a little miss on it. The rotor and cap were really bad so I changed them and the truck ran great for about a week. Now when cold it will run fine until it gets pretty warm and it will start to miss only sometimes. The worst is when I'm in 2nd or 3rd gear I start to bring the RPM's up and sometimes it will be just a noticable miss but then sometimes the engine will be jumping like crazy missing until I shift into 4th. Other times, also when warm, it will run fine through the gears.
When on the freeway there will be a constant miss about every 10-20 seconds as well. Plugs and wires seem okay but will probably change them soon and possibly fuel filter. What else would cause engine misses to be totally random like this?
Old 09-22-2011, 01:46 PM
abbazabba's Avatar
fule filter and check the plugs and timeing
Old 09-22-2011, 01:50 PM
A2theK's Avatar
Yeah I was going to run down to the parts store and pick up a new filter and wires. As for timing; where is the timing mark at on the engine? Is it on the timing cover somewhere? I tried looking but I think it may be covered in grease/dirt.
Old 09-22-2011, 01:53 PM
abbazabba's Avatar
ya its on the cover really hard to see its hiden by the belts and also
check the tps
Old 09-22-2011, 08:56 PM
A2theK's Avatar
Messed with the timing and it seems to be fine. Still missing pretty good. Changed wires and plugs and not too much of a difference.
Check the TPS and possibly new fuel filter? Any other things to check? It idles really rough and shakes the entire cab pretty good.
Old 09-23-2011, 03:43 AM
iselloil's Avatar
Head gasket leaking in between clyinders.Check the compression.
Old 09-25-2011, 06:52 PM
A2theK's Avatar
TPS checked out good, compression was good. Figured it had to be my injectors so I took a look at them and I'm almost certain this is the problem. These things definitely seem like they've seen better days. Going to have them cleaned at a local shop I know for about $25 an injector. Can't wait to have her running good as new!
Old 09-29-2011, 07:42 PM
A2theK's Avatar
Clean injectors = success! Running great!
icentropy
09-16-2020 02:47 PM
Sleaker
08-26-2020 06:03 AM
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
TDonkey
07-26-2015 10:14 AM
Quick Reply: 22re Missing Sometimes?
