22re lower intake removal
Old 08-11-2009, 05:34 PM
xwing777's Avatar
Whats the quickest way to remove the lower intake (the upper is off already along with the fuel rail, etc..) on a 91' 22re? All the bolts are out and its just laying to the side right now. I dont see an easy way unless you remove the entire wire harness as it goes through the middle of it.
Im in the middle of a head replacment and want to clean everything up before re-assembly.
This is an auto 4X4 if that makes a difference.
Old 08-12-2009, 03:37 AM
xwing777's Avatar
still dont see an easy way other than removing the entire harness
Old 08-12-2009, 05:23 AM
Lumpy's Avatar
I pulled the harness out...you got to get it off of the tranny, that's the fun part.
Old 08-12-2009, 05:28 AM
93YotaGuy's Avatar
The harness is easy. I just did all of this a few days ago. Pull the O2 sensors, the plug off of the transfer case, the two on the tranny, and you are good to go. Then all you have to do is feed the wire through the middle of the intake and it will come out. The rest of the harness can be left in there. It may seem like kind of a pain but it is rather easy.
When I pulled mine I was able to re-tape it all up and through it back under nice and clean.
When you put the harness back through its nice to have someone under the truck while the other is feeding it through from the top. It can be done by yourself cause that is how I did it but I kept thinking it would have been easier with someone helping.
Good luck!
Old 08-13-2009, 09:02 PM
xwing777's Avatar
ok i got evertihng loose now EXCEPT one wire that appears to be plugged into the transmission INSIDE IT? it has a boot that i pulled up and found a small bracket locking it into the trans. Once i removed the bracket i pulled the plug out and wires continued into the trans. (this is on the drivers side btw). Dont tell me im going to have to drop the trans pan too....or am i?
Old 08-13-2009, 09:09 PM
RMA
RMA's Avatar
no follow it the other way and disconnect it , leave those wires in the tranny.
disconnect it on top of the tranny.
Old 08-13-2009, 10:08 PM
xwing777's Avatar
is the connector near the gear shift area? (this is an automatic if there different)
Old 08-14-2009, 04:51 AM
Lumpy's Avatar
There has to be a plug somewhere...I agree with RMA and follow back. Mine is a 5spd so...they are a wee bit different.
Old 08-17-2009, 07:04 PM
LITLRED's Avatar
If you remove the FR tire and the access pannel in the RH wheel well the you should be able to easily reach the 3 (I think) connectors that go to the tranny/transfer case.
Doug4320
03-24-2018 10:11 PM
steve miller
10-10-2015 01:40 AM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: 22re lower intake removal
