22RE Leaking Fuel Injectors
Old 10-18-2009, 09:17 AM
Walt's Avatar
Just finished re-building my 22RE (88/93 mixed breed) from the crank to the valves. I can't seem to stop my fuel injectors from leaking.
The fuel injectors, while removed were sent out for cleaning and flow calibration, all checked out great, they were returned with all new seals/O rings. After install and start up of the engine the injucters leaked big time from the pressure side (ie the fuel rail).
Pulled off the whole throttle body to replace the O rings and reinstalled. I have now done this two times and am getting ready to do it the third time. I have been putting plenty of lub on all seals during install.
Anybody have any comments???? Insight or what ever....
Walt
Old 10-18-2009, 09:19 AM
Junkers88's Avatar
What are you using to lube the o rings?
Old 10-18-2009, 09:25 AM
Walt's Avatar
junkers88
I'm using a Moly based lub - I'ts the same lub that ARP uses on their studs.
Walt
Old 10-18-2009, 10:50 AM
Junkers88's Avatar
I think the service manual recommends using gas. I know when I replaced my injector seals I used gas to wet them a little and they dropped right in.
Old 10-18-2009, 01:14 PM
CHEEZBURGER's Avatar
I am glad you posted junkers, I was just going to use mayonaise, but really, I didn't know what to use and that saves me searching in the near future... YAY
Old 10-18-2009, 01:47 PM
Junkers88's Avatar
Mayo may go good on a cheeseburger but not so much on an injector....
jbv808
08-06-2021 04:47 PM
Eggslinger
06-08-2019 03:32 PM
Doug4320
03-24-2018 10:11 PM
steve miller
10-10-2015 01:40 AM
karbin
07-05-2015 11:37 PM
Quick Reply: 22RE Leaking Fuel Injectors
