22re knocking/rattling video inside.
Hey guys, first time poster but long time lurker. I purchased my first Toyota back in February. Its a 1988 ex cab with a 22re with about 115k on it. Truck has 233 on the body, but has been sound. I'm coming to you now with my first issue. My trucks engine is making a knocking/rattling noise that I am clueless as to how to diagnose and rectify. Before I slapped down some money for a shop to look at it I thought I would bring it your way and see if maybe its something I can do myself. Any help is much appreciated and I look forward to being a member of the community. Cheers!
The prominent noise to me sounds to me like an exhaust leak. Does the noise come from the exhaust side? Does the truck sound abnormally loud with the hood closed or louder when pressing the gas? I'd crawl under truck and look up at where the exhaust manifold meets the downpipe. There should nuts holding this junction together, are they all still there?
The smaller rattling noise sounds more like it is the standard broken timing chain guide issue. All my 22res have had this happen. The timing chain guide breaks, the chain then slaps against the aluminum timing cover housing and eventually wears through it into the water jackets. Here is a pic on what to look for with the valve cover off:
And welcome to the forum!
It's highly unlikely that both the exhaust leak and chain noise started happening at the same time.
Yes, it could be an exhaust leak, but that is not the first place I would start. I would get a mechanics stethoscope and look for the noise at all places of the engine. That will tell you where your noise is. Then dig deeper from there.
But...it sounds like you spun a bearing in the bottom end.
crashburnoveride
07-10-2015 06:39 AM
