22RE Intake Upgrade/Swap
Old 08-24-2008, 11:39 AM
myyota's Avatar
There was a thread on here about 6-12 Months ago were someone on here swapped an intake from an early 90`s 22RE onto an 85-88 22RE (i can`t remember what year it was) because they flow better than the early intakes. I have an intake off a 90+ 22RE that i want to swap onto my truck, but i can`t find the thread, ive searched but maybe im not using the right search words, does anybody remember this thread ?, if so could you post a link to it.
Thanks
Old 08-24-2008, 06:30 PM
myyota's Avatar
^Bump^
Old 08-24-2008, 07:37 PM
abecedarian's Avatar
allegedly the late manifold / throttle body flows a bit more because the early manifold has the throttle body turned down and the late has it straight into the manifold.
I've never seen a flow comparison between the two myself. But there shouldn't be any problems with the swap, other than maybe the late throttle body and ducting might hit the hood.
Old 08-24-2008, 08:47 PM
myyota's Avatar
The manifold and throttle body are a direct swap, my question was more about the vacuum line conections, the newer intake is a bit diferent as far as the vacuum lines go.
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
steve miller
10-10-2015 01:40 AM
Tacoma1313
08-17-2015 05:44 PM
Quick Reply: 22RE Intake Upgrade/Swap
