22re idle video
22re idle video
Video on youtube of my 22re. I've been fine tunning it for a while and need and input on how its idle is.
http://www.youtube.com/watch?v=OPGlfm-wxuY
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Like I said, it sounds just a smidgeon on the high side, but sounds like just 'bout every other 22re I've heard. Sounds pretty good, tho.........could just be me tho....
ADJUST THOSE VALVES!!! Dont worry though. The valves on my '93 were worse sounding than that, even after adjusting them 4 or 5 times. The idle might be a little too high. What is it set at right now?
wow, yeah sounds like the valves are still not adjusted right; have you adjusted them warm?
it's hard to tell idle speed by sound; I'd get a cheapo tach so that you can be certain; or I've seen some nice timing lights that have the function too
oh yeah, holy HELL that motor's clean looks nice
Well the high idle is normal if its cold. Mine would idle at 2400 rpm when it was -40F on start-up. The low idle you can adjust to 750-800 rpm very easily. You just need a flat-head screwdriver. What engine do you have?
Its an 86 22re. But yea i'm gonna see if i can play with the idle alil more. But yea me and my dad have tired countless times to adjs valves but the still get chatter.
Seems like the temp outside has a difference in idle a bit i'm sure its supose too but yea. Like that video it took of it was on a 80 degree day and it idled at 900-950 and today it was 50 and it idled at 1000-1100
yeah man thats completely normal. the idle is controlled by the temperature of the coolant. It idles higherr when its cold to warm the engine up faster. Like I said in my previous post, when it was -40F here, my idle was around 2400rpm until the engine warmed up.
montanatruck
02-26-2017 07:07 AM
