22re header ?
Old 06-27-2006, 04:17 AM
CGOULET's Avatar
22re header ?
i am going to get an intake made, and make a 2.25" exhaust with single in/out flowmaster and high flow cat, and im going to installl a header.
my question is what brand do you suggest? i was thinking thorley, its like 235. is that a good brand? also will the air tube located on/over the stock ex manifold be used? or do i even need it?
thanks, chris
Old 06-27-2006, 08:12 AM
Sonofmayhem's Avatar
Ive heard downey was a good header and thorley, but what engine are you working w. and i belive the air tube will be used. I think it deals w/ emmisions but im not sure.
Old 06-27-2006, 03:13 PM
the_supernerd's Avatar
When I researched headers, I found that LC Engineering and Thorley were best. I was going to get an LC Engineering one, but I changed my mind because they raised the price to $350. I was thinking about welding a 2" or 2.25" pipe on the lower part of the stock collector (I think that is what it is called, the part after the manifold). This would also involve getting a new Y connector. This would take out a lot of the restriction in that pipe. I am not sure if it would be as good as a header, but it would be a lot cheaper.
Old 06-27-2006, 03:31 PM
EWAYota's Avatar
LCE, NWOR, Downey, Thorley
Do a search, theres actually a good size thread about it on here.
Old 06-27-2006, 05:51 PM
Elton's Avatar
the best fitting header is a lce i had one and it was awsome it cost a little more but its stainless steel and ceramic coated
Old 06-27-2006, 05:58 PM
AH64ID's Avatar
Here is the thread I did a few months back on what I found. I ended up with LCS and a car sound cat, with a 60 series flowmaster... it was AWESOME for the 1K miles I put on it before my HG blew.
Old 06-27-2006, 06:12 PM
Elton's Avatar
^ pretty much what i did but i got a flowmaster delta 40 and wow did that make the 22re sound sweet
Old 06-27-2006, 06:43 PM
javadoody's Avatar
what year is your rig? you may not need the cat. i believe early 90's had basically a hi flow cat stock.
Old 06-27-2006, 07:04 PM
javadoody's Avatar
found the thread.
https://www.yotatech.com/forums/f2/stock-hi-flow-cat-66223/. check out 4Crawler's response.
Old 06-27-2006, 07:54 PM
AH64ID's Avatar
yep...but a aged cat gets clogged and looses flow, they wear out just like the rest of the exhaust.
Old 06-28-2006, 03:44 AM
CGOULET's Avatar
its a 92 with a 22re
Old 06-28-2006, 05:06 AM
CGOULET's Avatar
thanks for your help guys, i think im gonna go with the lce header, its seems to be the nicest and about the same price as the coated thorley.
Old 06-28-2006, 08:36 AM
CGOULET's Avatar
i was just looking on ebay and at summit's ebay store i found teh thorley header with bung for O2 for 200 inc shipping, think it is worth it to just pick that one up?
Old 06-28-2006, 08:56 AM
AH64ID's Avatar
by o2 bung, you mean the connecter pipe from the header to the cat? since in 92 the o2 sensor is back by the cat?
Personally, I had a non cermaic header, and it was fine.. but I now have a ceramic and like it much better.
Old 06-28-2006, 11:32 AM
CGOULET's Avatar
ya the connector pipe has the spot for the sensor, and its a non coated, i think i can deal. you think its worth the extra 150? im kinda strapped for cash....
Old 06-28-2006, 11:41 AM
deathrunner's Avatar
I like my thorley, for what it's worth.
Old 07-06-2006, 07:44 AM
CGOULET's Avatar
just ordered a ceramic coated thorley for 261! the un coated was only 202, but i figured it wouild be worth a lol extra. also got me a magnaflow cat for 63. not a bad deal i think
Old 08-14-2006, 10:04 AM
Christyle's Avatar
so now im looking into a header...
which of LCE's headers are you looking at? I only saw the one thats made for a 22re/turbo and its $765...a lil much for me. The rest are 22r headers (I assume they work for 22re as well?) but they seem like theyre for street/racing applications? Which one should i be looking at?
Old 08-14-2006, 11:32 AM
Elton's Avatar
the 22r is the same as the 22re you want to order the street header kit
Old 08-14-2006, 12:00 PM
not nessesarily true, i bought a 22r header and it didnt work w/ my 22re. but i would trust the company and look at the bolt pattern, thats where i got screwed.
Quick Reply: 22re header ?
