| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE Head & head gasket replacement tips????!!
#2 (permalink) |
lots of pictures, lots of plastic baggies and a sharpy and some tape so you can label whats what.
Take your time and label and bag everything, nuts, bolts and hoses. When you take your timing cover off, make a template with cardboard so that you remember which bolt came from which hole. For the most part its easy but 2 of the longer bolts switched could cause some issues. When you go to take the intake manifold off, remember the hidden allen bolt and the hidden bolt under the valve cover that goes into the top of the timing cover. It will be covered in a puddle of oil.
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Preping for SAS...... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#3 (permalink) |
Label everything, be very organized about everything you remove, make sure to buy new head bolts, if it were up to me I would remove the whole engine and rebuild if I had that problem.
__________________
Aaron 1989 Ford Probe GL 2.2L, 4 cly. ~240K 1991 Toyota Truck Extended Cab, 22RE, 30'' BFG ATs, 5 spd, 183K SOLD!! 1987 Toyota Pickup std. cab, 22ret, 31'' BFG ATs, 5 spd. , 155K SOLD!! Pictures http://community.webshots.com/user/volsg8rh8r |
#4 (permalink) |
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#5 (permalink) |
The bottom end is in good shape. There's no water in the oil, so I caught it early. It's got 180k mi and I got a NEW assembled head for $280 with all the gaskets. I ordered the new head bolts yesterday. It was getting hot and steam was blowin out of the tail pipe along with exhaust fumes coming from the radiator. Head gasket, or cracked head.
#6 (permalink) |
I thought about an engine rebiuld, but toyota's run so long because they were built with such tight tolerances. Rebuilt 22RE's won't last long cause the original factory tolerances aren't held on a rebuild. They are close, but not as close as the japs. I drive this damn thing everyday for the gas mileage and I wheel almost every weekend.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE Head Gasket and Timing Chain Replacement PICS | all_terrain17 | 86-95 Trucks & 4Runners | 205 | 09-11-2009 05:05 AM |
| 95 3RZ-FE head gasket replacement tips? | t100bob | 93-98 T100s | 0 | 09-07-2007 04:49 PM |
| Head Gasket Replacement | mudbog | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-25-2006 05:36 AM |
| 22RE Head Gasket replacement - OE Toyota or aftermarket ok? | AllCammedUp | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-06-2003 07:38 PM |
