22RE gas path
22RE gas path
The gas line from the tank seems to come to the fuel filter and then into the fuel rail. The fuel pressure regulator bolts right onto the fuel rail and the injectors are connected to the fuel rail.
I am having difficulty seeing the path of the gas so that the regulator actually controls the pressure to the injectors.
Are there some separate passages within the fuel rail.
Can someone explain? Thanks, Dave
Fuel Pump on RE22
Thanks, Wyoming9 that's what I figured and just needed to confirm.
I have determined that the check valve on my fuel pump is bad. Rail pressure drops to zero immediately when engine is turned off. Also watched the fuel pressure after pressurizing, pinching supply fuel line and return line (engine off) and then releasing flow in the supply line and pressure drops to zero immediately
What symptoms is a bad check valve likely to show?
Thanks,
Dave
Thanks,
Dave
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
