22re "fires" wont run. Whines
I replaced the head gasket on my 87 runner.
22r with efi attached.
If I mess around with the distribution, it will either run for a few seconds and then die or it just won't fire at all.
Either way, there is a strong whine coming from in or on the motor.
It acts like a miss fire, it has spark and fuel.
Belts are okay, valves are adjusted.
Help me and the truck to stop whining please!
"whine" is often the distributor. You can use a fancy-pants stethoscope http://www.harborfreight.com/mechani...ope-69913.html , but I've had good luck using the tube inside of a roll of paper towels.
You DO have the induction all hooked up, don't you? If you don't have air running through the VAF, the fuel pump only runs with the key turned to start. Once you let go of the key the pump will stop (air flowing through the VAF keeps the pump running).
09-04-2015 09:27 AM
mengquis
07-13-2015 10:39 AM
