22re engine stall
22re engine stall
i am new to this forum but have heard a lot of help is offered on here.i have a 89 truck with a 22re. just recently it has started to stall or stutter when accelerating. i installed new filter and seem to be getting plenty of gas.it turns over and will start after a few windings.it stalls when mashing gas pedal quickly but will keep running if you let off. thanks for any help,been scratching head alot
I would check the intake plumbing for hidden leaks. Not uncommon for the rubber bellows sections to develop cracks and let in un-metered air, especially when you change throttle setting and that causes the air flow to change and that flexes the rubber and opens up a crack:
- http://www.4crawler.com/4x4/CheapTri...shtml#AirLeaks
steve miller
10-10-2015 01:40 AM
Jnkml
07-06-2015 01:20 PM
