22re electrical nightmare
I pulled my motor (89 22re), put a new clutch in, replaced all of the gaskets & seals and put it back in and now my truck has these symptoms:
When I crank the motor it will rotate once or twice and then the starter will spark. When cranking the motor the ground strap on the drivers side gets hot, I suspect that this one might not be a ground strap at all as it is an insulated wire so I think I have it connected incorrectly, it comes out of the same group of wires that connects to the alternator. When I pulled the distributor out and put it back in the coil and the distributor sparked.
Check the factory service manual for the wiring...do a search for factory service manual. Should be easy for ya ta figure out.
Ok...the broken off fingernail in your avatar hurts to look at...ouch@$%#^!
Sounds like you might have some loose connections.
Your ground cables are not giving you a good ground so all current is trying to find a ground.
A few wires hooked up wrong also??
The Toyota electrical manual for your vehicle just makes wiring problems so very easy to troubleshoot
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
v_man
07-23-2015 04:01 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
