| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22re driving me crazy!
#2 (permalink) |
Did you pull the ECM codes to see what error the CEL was giving you?
Mike in AR |
#3 (permalink) |
Have you ever replaced the fuel pump? It doesn't sound exactly like the issue I had before I had to replace mine but it does sound like a fuel delivery problem.
#4 (permalink) |
Check your raidator fluid, when my throttle started jumping it was my head gasket that had blown or had a leak and there was exhaust in the raidator fluid. Have someone test your fluid for exhaust gases.
#5 (permalink) |
I got a code 14 but it was still getting spark. I don't know if its the fuel pump or not I jumped the Fp and b+ terminals and could hear the fuel pump running when the ignition is on but it still does the same thing even with the fuel pump terminals jumped.
#6 (permalink) |
When is the last time you changed your plug wires? The insulation wears thin quicker on cheaper wires, too. They'll look o.k. or possibly dry-rotted, but they'll be too thin to keep them properly insulated from each other.
__________________
1989 Toyota 4runner DLX, 22re, 4WD, on 31x10.50x15's(I'm sitting soooo high), Smittybuilt double-tube rear bumper, extended diff breather mod (front and rear diffs), Cobra 29 CB, 4ft Firestik, OME Nitrocharger shocks Active member NAHC and DU "Anybody ever tell you those look like two raw eggs hanging from a nail?"-What not to say to a chick at Bike Week Redneck's last words-"Hey Bo, watch this! |
#7 (permalink) |
i replaced the plug wires and it didn't help at all. I believe the problem is the pickup coil in the distributor it tested fine cold but I tested it again when it was warmed up and started running badly and the ohms weren't in spec so I ordered a new one and hopefully it will be fixed finally.
#8 (permalink) |
So did the new pickup coil fix your problem? Just wondering so in case anyone does a search they'll have a few possiblities narrowed down. Hope it did fix it, though. It's nice when it's something minor.
__________________
#9 (permalink) |
i have the same problem........ help what was the result?
i've got the same problem exactly like how you described it. What did it turnout to be?
#10 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Had a similar thing happen on my 88 and it was the igniter failing.
__________________
Quote:
Insomnia: it's a way of life.
#11 (permalink) |
I say fuel pump. It can be running and not putting out the pressure or the flow thats needed.
__________________
1991 PU bone stock. Engine is bored .020, .010 off the head, .010 off the top of the block, ported, pollished, and completely ballanced (I think thats all, I can't remember). Just needs a cam. *****FOR SALE***** 1990 PU SAS, 5 link front and rear, welded rear, Vortec V6, 700R4 trans, bobbed 22", buchet seats, B&M shifter. |
#12 (permalink) |
The same problem happened a few times in my 1990. It even happened when I went for a test drive before I bought it... I didn't try to figure it as I have another good running 22RE that I want to install in it when this one dies (or maybe before!). The "check engine" light stays off when driving.
| Tags |
| 22r, 22re, 4runner, 87, check, coil, engine, fuel, jumped, light, pickup, pump, random, run, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help! YouTube driving me crazy | rubysRunner | Computer Talk | 21 | 02-18-2007 04:25 PM |
| Alarm system driving my crazy | drguitarum2005 | Alarm Systems | 2 | 11-26-2006 09:38 AM |
| Overheating driving me crazy | WillRadford | 86-95 Trucks & 4Runners | 10 | 07-21-2006 09:12 AM |
| wireless is driving me crazy | shazaam | Computer Talk | 10 | 03-18-2006 08:47 PM |
| This knocking is driving me crazy!! | DH6twinotter | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 01-27-2003 09:46 AM |
