22re cylinder head replacement/timing chain adjuster help
Old 03-31-2016, 04:48 PM
gixxer's Avatar
I replaced my cylinder head on my 22re...I forgot to put a wedge down into the timing chain tensioner to keep it from coming out...well now I can not put the cam gear back on. Is there any way to release chain tension without removing the timing chain cover so I could put the cam back on ?
Old 03-31-2016, 11:42 PM
wyoming9's Avatar
Red face
It has been a few years
So the old tired brain might not recall correct
I never used anything to hold the chain tensionor
Put the bottom all together set the head on then put the cam gear on
Someone with fresh memories might have a better idea.
First I heard about this wedge idea
Old 04-01-2016, 11:57 AM
gixxer's Avatar
I was able to stick a long rod down in there and push the adjuster in, then the cam went on without any problems.
https://www.yotatech.com/forums/f116...t-22re-159401/
Old 04-01-2016, 08:24 PM
85TurboRunner's Avatar
Old 04-04-2016, 06:36 PM
an1176's Avatar
Put part of the chain on the cam sprocket the put sprocket on cam then turn the cam until the chain goes back on. Like you would with an old bicycle chain and sprocket.
millennium falcon
03-19-2017 05:42 AM
bluAM2
09-15-2016 09:35 PM
d-wood
03-08-2016 07:40 PM
an1176
03-03-2016 03:26 PM
Naked Runner
02-16-2016 05:36 PM
Quick Reply: 22re cylinder head replacement/timing chain adjuster help
