22re cam bolt
22re cam bolt
i cant get the bolt on the end of the cam off so i can take the gear off to remove the timing chain then the head. i cant find a 'flat spot' on the cam to stop it from turning....
dont have one here right now...my buddy has my compressor for the next week. i guess i can wait...its just my spare motor i was gonna tear down, clean and get it ready to rebuild
just put a long breaker bar on the crankshaft pully and put her up against the driverside frame rail and then take off the cam bolt or if you dont have one long enough or an exta set of hands i got mine off with a screwdriver through one of the holes in the cam gear up against the rocker arm assembly
SHOULD be the cam bolt as its only tourqued to 55 flbs and the crankshaft is supposed to be 116 but ya never know what some other guy did, good luck and you should be able to put a pretty short breaker bar to the floor
hehehehe i JUST put my head and stuff back on so i knew right off hand...gonna go outside and put water in the rad and fire her up as soon as it stops stormin
thanks for the help everyone...the head and timing cover are off. good luck with your motor....ive got to do the same to my 22re in my truck....the head gasket went on me after 6000kms so ive got to go through this all over again and see if theres any major damage. i sure as s hit hope not
bah that sucks, i had to do mine cuz i messed up started out getting the timing right so i took the t-cover off then when i put it back on i messed up the head gasket so i went and got a head gasket then when i was re-tourqing i bent a valve and broke a valve guide....so i just now got the head back from the machine shop with a new valve and valve guide...lmao so my lil 10 dollar 2 hour endevor ended up costing me like 3 weeks and close to $160 bucks...(i tried buying another head and it was the wrong one) so yeah i feel your pain!
09-04-2015 09:27 AM
