22re build up
22re build up
okay so me and apalmer1 are building up a 22re this is going to be a budget build yet we want some power! we already have the intake and exhaust taken care of, but it needs to breath better so what tolerances could we get away with when we bore the intake and exhaust on the head?
next would be decking the head. how much could you actully take off? i mean there isnt much there to shave.
so far we have totally dismantaled the engine cause we didnt know what shape it was in plus its kinda nice getting familiar with something that important in our lives lol. the bores looked good and the pistons are useable. apalmer1 should be posting some pics later today, if not i will.
oh and to anybody else that reads this how should i go about taking out a stripped crank bolt? the head of it is stripped but the threads are fine.
Just the head? Hmm...have you tried some vice grips? Maybe grind the edges down or use a 6 point socket 17mm socket. Good luck!
Vise grip, pound on a slightly smaller 12 point, or weld on a new bolt? Careful for heat on the weld one...maybe that is a bad idea here...may not want to pound on the crank either....sooooo....vise grip?
As far as the head bolt goes you can take a nut that is a little larger, drill out the threads so its smooth and slip it over the bolt. Then weld that nut to the bolt from the top. Basically fill the hole with weld and be sure to grab some of the nut with the weld. Let it cool, tap it with a hammer a couple of times, spray some lube around the threads on the head bolt and put an open end wrench on it to take it out. I say use an open end wrench so you can see if the weld starts to break out, if it does reweld and try again. Be sure to let it cool off or it may twist.
A caveat here....... I've never done this myself but have seen it done on old Ford tractors when something like this breaks.
Luck!!!
Luck!!!
you may be able to drill the bolt and use an easy-out. or just grind the head off the bolt. or grind grooves into the head of the bolt in an x pattern... or ...
from my expirences with striped bolts.. use the easy out option as a last almost hail marry attempt ( it will piss your face off real good when you break one off and have to try and re-drill through it) vise grip.. not going to work to my oppinon.. unless you have terminator sized arms... they do make sockets that have groves like an easyout in them that will grab on rounded bolts.. but i think in this case id try welding a nut to the top of the bolt, just dont go wild with the welder.. just short burst so you dont cause any warping or cracking, also put the ground as close to the bolt as you can.. possibly hold the nut on the bolt with the ground clamp. that way when a arc is struck it does not arc between main caps, crank, block, ect..
by bore the intake and exhaust are you referring to the valves or porting?If you're looking to up the compression ratio, I'd rather see you do that with the pistons than milling the head. Gives you some extra head room (pun intended) if you blow a head gasket. If you do mill the head down, I wouldn't recommend more than .50mm off.so where's the pics already?
as mentioned, plastigauge is something cheap you can use to measure crank and rod bearing clearances. you cut a piece of it off, lay it on the bearing journal then torque the cap down... then remove the cap and measure the plastigauge with a scale they give you (hi-tech piece of paper you lay down next to the plastigauge) and viola! bearing clearance.
be real careful if you weld a socket or nut or other bolt to the existing bolt- you don't want to end up welding the bearing cap to the block during the process.
we basically too the best one of these 22rs
tore it down
i thought the bores looked good but theres like 15 thousandths taper in them so i guess im going over on the size
the damn bolt, i think im going to weld a piece of angle iron on it and beat it with a hammer.
why does the exhaust valve look like this only on the #4 cyclinder?
sorry for the wait i have been busy with winterizing the shop.
http://www.engnbldr.com/head_shop.htm
does this guy do good work?
hahaha believe it or not i seen that one coming. as far as shattering your driveway i dunno, bloody ear drums are definatly possible
