22RE Anti-freeze Loss
Old 03-13-2008, 12:51 PM
yoterBoater's Avatar
Unhappy 22RE Anti-freeze Loss
I have a 22re with recent redone headgasket and i am having to put water- anti freeze in weekly. It seems to be over flowing because when i stop and i look underneath there are lil droplits of water leaking?!?!?! I also had the radiator boiled and checked when i re did the head???
Old 03-13-2008, 12:54 PM
EWAYota's Avatar
check your hoses for leaks? I've got a small leak on my bypass hose (think thats what it's called) that comes out of the water pump. Likes to drip onto the alternator. Can you see where the fluids dripping from?
Have you checked your oil to make sure its not seeping into the head?
Old 03-13-2008, 12:55 PM
Justinvd's Avatar
Is your temp guage working normally?
Old 03-13-2008, 02:18 PM
dcg9381's Avatar
These motors can stay cool with a lot of water loss, especially when it's cool outside.
The key to this issue will be determining where the water is leaking from - tell us that and you'll get a lot more help..
Old 03-13-2008, 04:08 PM
black diamond's Avatar
did u do a timing chain? replace cover? chain will groove cover into water jacket, cause coolant loss. how many miles?
Old 03-13-2008, 04:28 PM
HelliphinoN8's Avatar
The timing chain would make a crap load of noise before it would wear thru the cover. Hopefully you'd freak out about the noise and take care of it before the worst happened.
Sleaker
08-26-2020 06:03 AM
JaredL
03-28-2016 09:08 PM
Tacoma1313
08-17-2015 05:44 PM
Koolbananass
08-12-2015 01:59 AM
nate2919
08-06-2015 04:00 AM
Quick Reply: 22RE Anti-freeze Loss
