22RE aftermarket temp gauge
I'd like to install an aftermarket temperature gauge as a backup to my intermittently-working in-dash gauge (SR5 cluster). My question is, where is the best place on the engine to install the aftermarket sender without eliminating the factory sender? My existing problem is a faulty gauge (and not the factory sender) because a good, hard slap on the underside of the instrument panel will wake the gauge up for a little while.
87 4Runner SR5
22RE
5 spd.
87 4Runner SR5
22RE
5 spd.
I thought of that, but was concerned that unless the tee could vent (which wouldn't be a good idea), the sender might be suspended in hot air, and not hot water as it is meant to be, and that may give an incorrect reading. But I could be wrong...
you could make a piece. cut top radiator hose in half and fashion a copper union in there with a port for the sender, some guys run like this for an electric fan thermostat no pretty but it works
The following users liked this post:
Phansigar0614 (03-17-2020)
You should search. I found this in about 40 seconds:
http://cgi.ebay.com/ebaymotors/Water...Q5fAccessories
the1998sr5
15
07-14-2020 08:35 PM
Jeffreynmandy
07-18-2015 08:26 AM
Poncho0206
07-10-2015 06:21 PM
