22re acting up please help
Old 08-29-2013, 03:19 PM
yota8888's Avatar
I have a 22re that starts right up cold drives fine sometimes farts a little theb when i start back up it cranks forever and i have to pump gas to get it going then last time its even harder to start even when cold ran it for 3 min and exhaust was red hot but engine wasnt abd had to keep it high rev to run
Old 08-29-2013, 04:38 PM
Rerunn's Avatar
Cold start injector time switch
Old 08-29-2013, 05:00 PM
yota8888's Avatar
Its a 1987 truck 4x4 that sitch could cause all that?
Old 08-29-2013, 05:07 PM
Rerunn's Avatar
Yep there is a tsb for it
Old 08-29-2013, 05:21 PM
yota8888's Avatar
Ok thanks
Old 08-29-2013, 05:56 PM
Kiroshu's Avatar
x2 on Cold start injector Circuit.
Old 08-30-2013, 12:34 PM
yota8888's Avatar
The cold start injecter switch wasnt it any other ideas thanks
Old 08-30-2013, 12:45 PM
john22rebuilder's Avatar
I had a bad plug wire that wouls short when hot couldnt see it but could hear it. At highway speeds(i assume) the injector on the dead cyl still dumps gas and it would get burnt up at the cat and muffler mine got so bad both glowed red!!!! Taped the wire till i could buy wires problem dissapeared . Try it at night spsrk could be visible....
Old 08-30-2013, 12:49 PM
yota8888's Avatar
Ok i cut the cat off now so the exhaust isnt screwing with iti have a spaer efi set i was gonna start swapping sensors
Old 08-30-2013, 05:55 PM
Kiroshu's Avatar
Cold Start Injector malfunction... leaking...?
Coolant Temperature Sensor(ECT) malfunction...?
Doug4320
03-24-2018 10:11 PM
wafoogalla
11-02-2016 11:02 AM
HollieJayyy
08-09-2015 07:59 AM
Nickyodaman
07-27-2015 12:13 AM
jgallo1
07-22-2015 04:21 AM
Quick Reply: 22re acting up please help
