22RE AC Compressor belt tension pulley
Old 06-23-2016, 07:54 AM
DCMatt's Avatar
'88 4Runner 22RE with AC. I need to change the alternator belt but can't get the A/C compressor tension pulley to move.
I've had 2 other 22RE's with AC and both had the tension pulley below the compressor (easy to reach). This one is different. Anybody worked on one like this?
Is the circled bolt what I need to loosen? It is a b!tch to get to...
Old 06-23-2016, 01:25 PM
RJR
RJR's Avatar
If it's like the 3vze, the AC compressor idler pulley has a jack-screw type adjustment for tension, so just loosening the mounting bolts won't allow it to move. You have to back off the jack screw tensioner after you loosen the hold-down bolts.
Old 06-23-2016, 03:53 PM
DCMatt's Avatar
Thx for the reply. I guess I was just too tired and frustrated (or stupid) yesterday to see it.
Looked at it today and figured it out. I was trying to make it harder than it was...
My truck is running again.
Old 05-20-2019, 10:59 AM
Anomale's Avatar
Hey Guys Sorry to revive this thread but I'm helping a friend change his belts and have the same setup as in the picture. I've looked all around the tensioner pulley / bracket and can't find a bolt that would adjust the tension. From looking at the picture can you tell me where the adjusting bolt is located? or what steps need to be taken to loosen the belt?
Thanks
Old 05-20-2019, 06:16 PM
Paul22RE's Avatar
Does the compressor have a slot for movement on the other bolt that holds it on that you can't see in the photo? Might just have to loosen both bolts that hold the compressor and rotate it to loosen the tension.
Old 05-21-2019, 10:12 AM
Anomale's Avatar
I looked underneath and don't see any way to adjust the compressor itself bolt holes are not adjustable. Here is a picture of the view from underneath
Old 05-21-2019, 11:30 AM
Paul22RE's Avatar
Loosen that bottom bolt holding the pulley arm, looks like it may rotate or slide down to loosen the tension.
The following users liked this post:
old87yota (05-21-2019)
Old 05-21-2019, 06:24 PM
Anomale's Avatar
Yep that was it Thanks.
vikecowboy
02-09-2016 07:31 AM
IMCOLOR
01-31-2016 04:51 PM
Kj94runner
01-27-2016 12:01 AM
rpeAMP
09-26-2002 09:58 PM
dukestr
08-20-2002 08:14 AM
Quick Reply: 22RE AC Compressor belt tension pulley
