22R will not idle
Old 03-17-2008, 07:31 PM
rods's Avatar
22R will not idle
I have an 86 truck with the 22R carbed engine. It will not idle. I have kitted the carb, and even put on another carb to try, same problem. Runs good on fast idle, kicks down to idle and just dies. I tried to just speed up the idle, still does not run right. It is running very rich.
Is the idle cut-off solenoid a possibility? It will not click when I apply voltage.
Any other ideas or suggestions to check out?
Thanks for any help!!
Rod
Old 03-17-2008, 07:38 PM
ozziesironmanoffroad's Avatar
hows your choke? i dont know much about carbed motors, but i do know if your choke is not workin right, it wont run right.
Old 03-17-2008, 10:15 PM
87toy.'s Avatar
those asian carbs have alot of funky stuff on um, did u rebuild the other carb you stuck on it?
its hard to say whats causing it not to idle, it could be your fuel air mixtue, u said it is running rich, it could be your idle valve, or choke, could be a vacume leak, especially if the carb u stuck on it is rebuilt,
Id check all your vacume connections. start pulling hoses and see if there is a difference and once u pull a hose and nothing at all happens that could be your culprit.
Blamalam
03-12-2022 07:34 AM
dumpster84
04-30-2016 06:03 AM
87blyota
08-23-2015 03:57 AM
Fakayayou
08-09-2015 12:47 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: 22R will not idle
