22R Timing Question
Old 11-24-2009, 11:10 AM
1Digger's Avatar
22R Timing Question
I have an 87 4x4 with a freshly rebuilt 22R. I am running a Weber 34 DGEC and a header. I have the timing set per the setting on the sticker under the hood, 0 with vac lines plugged from the dist, and it is dead on. My question is-should I advance or retard the timing a little based on my setup? It doesn't feel like it has the "snap" that it should. Anybody have any experience with this? Thanks
Old 11-24-2009, 11:20 AM
TOYOTA 1's Avatar
i would advance it 5 degrees.
my friend has a similar setup and he says its noticeably better at 5 degrees advanced.
Old 12-02-2009, 05:34 PM
MT. GOATA's Avatar
I'M HAVIN THE SAME PROBLEM! FRESH REBLD. 22R. 32/36WEB. Lc.HEADER. 8MM WIRES. ELCT;FAN & FULEPUMP W/REG... NO SMOG. CLEAN&BASIC. RUNS REAL ROUGH! TILL BOUT 3g's THEN KINDA SMOTHS OUT. WHEN I SHUT HER DOWN SHE BACKFIRES. I'VE DIALED HER TO SPECK'S COULD USE SOME HELP ALSO
bigjstang
08-25-2021 12:41 AM
Avenged
07-09-2015 07:55 AM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 22R Timing Question
