22r timing kit
22r timing kit
I have a 1987 toyota pickup I need to replace the timing chain and guides etc and I found this kit on eBay http://item.mobileweb.ebay.com/viewi...id=77719634158. I wanna know should I go with this or the 400$ for the stuff at my local dealership
You need single row kit for an '87 unless the timing cover has already been changed to accept the double row kit. If it is, in fact, an osk timing kit, go for it. Or, just check these out. Highly reputable vendor.
http://www.lceperformance.com/Timing...ts-s/14680.htm
Same here, Engnbldr is great. If you want to replace the oil pump, water pump, and timing cover the LCE 2 row conversion kit would probably be worth it. Same price your dealer is quoting you and it will last longer.
could you give me a web address for engnbldr
85-95 TOYOTA 2.4L HD Timing Chain Kit/Cover/Water Pump/Oil Pump/MLS Head Gasket
does something like this even sound like it would hold i know it is very cheap has anyone tried it before
this is the web adress
http://www.ebay.com/itm/85-95-TOYOTA-2-4L-HD-Timing-Chain-Kit-Cover-Water-Pump-Oil-Pump-MLS-Head-Gasket-/200781391576?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ebf80e6d8&vxp=mtr
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
