YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-10-2008, 05:34 AM   #1 (permalink)
camo31"10.50"'s Avatar
22R Headgasket???
so..ever since we got our '86 toyota 4x4 ext cab pickup its been having a couple of problems...first..the front pass. side axle is leaking grease from the boot...(fixin that soon) and whenever it got warmed up..i would idle rough..like it was only running on 3 cyl...fixed that for a while...but now its doin it again...and this mornin when i started it up...it would not idle worth a flip..it would idle high for about 5 or 10 secs...then idle low and sputter and cough then die...this is our DD..hopefully its not the headgasket...but if so...VW diesel swap here we come...so if anybody can tell me whats goin on..i'd appreciate it...thanks
__________________
1986 Toyota 4x4 extra cab pickup stock 22R 5spd with 35,000 miles on a complete rebuild pushin 200PSI in every cylinder...31x10.50 swamper TSL's...hating the IFS..loving the sound of a header and 2 1/4 exhaust hat dumps after the muffler (no more stacks)...lovin the look of the roll bar..cant wait to get the truck painted.
camo31"10.50" is offline
Sponsored Links
To remove this ad, register today!
Old 05-10-2008, 06:17 AM   #2 (permalink)
now water is dripping out of the tailpipe...a wet spot on the ground about 4in. in diameter..in about...15 seconds...or less..im trying to convince dad its headgasket...but it aint workin...
__________________
Old 05-10-2008, 07:41 AM   #3 (permalink)
now it wont stay running unless i give it a little bit of gas...is this headgasket or not...it has white smoke coming out of the exhaust..(it has never smoked ANY>....AT ALL since we got it...i mean NONE...and now its doin this)...i cant smell a sweet smell in the exhaust...but it is definately NOT drivable...so is it headgasket...or is there another culprit..thanks
__________________
Old 05-10-2008, 12:22 PM   #4 (permalink)
abecedarian's Avatar
Location: Climbing cell towers- the deadliest job in America
Wet spots under the tail pipe isn't necessarily a sign of a problem. One of the byproducts of combustion and catalytic converter operation is H20. When the engine and exhaust are cold it's normal for this 'water' to drip out of the tailpipe and make wet spots on the ground. Side note- that's why you always see 'steam' from tail pipes in the movies.
On the other hand, if you're seeing white smoke that disappears fairly quickly all of the time coming from the tailpipe, there's a good chance that the head gasket has failed.
When the engine is cold, pop the lid off of the radiator and start the engine. If you see bubbles coming up in the radiator while the engine is warming up but before the thermostat has opened, I'd say "YEP, yer ed gaskit's afailin'". If you get a big bubble when the thermostat finally does open that's a nail in the coffin.
And a headgasket is FAR cheaper than a VW diesel even when you consider buyin a new head if the old one's warped and fubar.
__________________
...relax and rest assured: my name is not allan.
Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan.
See, I'm being green.
Quote:
Originally Posted by SwampThing View Post
....But I'm happy to report that I have yet to have a good measure of sense knocked into me. Even when I was testing out my hardhat by runnin full speed into a brick wall, I am still sense-less.
abecedarian is offline
Old 05-10-2008, 04:42 PM   #5 (permalink)
EWAYota's Avatar
Send a message via AIM to EWAYota Send a message via MSN to EWAYota
Well, since you mentioned in another thread that you have a build up gunk under your oil cap, I'd say its very possible.
__________________
DJ
1994 Pickup
22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around...
Originally Posted By Fustercluck
"Proof that Gangus did not spontaneously generate....he has relatives."
Originally Posted By Tacoclimber
"My two year old better get a job, soon..."
Reply Posted By Oly884
"I hear coal mining is a great career."
Myspace
EWAYota is offline
Old 05-11-2008, 03:44 PM   #6 (permalink)
the buildup is on the cap of my '80...this is the '86...we've come to the conclusion that its headgasket...we're gonna run a compression test to make sure..if so..then its goin into the shop...we cant afford a swap right now...damnit...o well...the truck leaks more H2O than it should out of the tailpipe...i mean...a puddle on the ground about 6in. in diameter in about 10-15 seconds...yeah...thats alot..
__________________
Old 05-11-2008, 04:04 PM   #7 (permalink)
91Toyota's Avatar
Good luck with the compression test.
I have water coming out of my tail pipe when its cold. It will leave a mark on the ground. I've also only got 3 cylinders...so who knows.
I don't necessarily think it's the head gasket though. I would check compression though!
__________________
1991 Toyota truck 22re 5spd Shortbed Standard Cab 165k miles and counting...wait...its in pieces now:-P
Quote:
Originally Posted by abecedarian View Post
lol...
and I could take your girlfriends, number them one at time as you do them... and then turn out the lights and put them back in the room with you... can you tell them apart if they don't say anything?
You love Seafoam so much that in the bath tub, you pass gas and call for peeps to seefoam.
91Toyota is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1986 22R Headgasket change how long should it take? 1986Yotaboy 86-95 Trucks & 4Runners 1 06-28-2007 09:36 PM
please tell me its something other than my headgasket.... kpaxfaq 86-95 Trucks & 4Runners 10 09-05-2006 08:01 PM
Ok so its NOT the headgasket... rpeAMP 86-95 Trucks & 4Runners 13 02-21-2006 06:46 AM
Block casting #s on 22R (do make sure I have a late 22R before I buy parts) Los Gatos? 95.5-2004 Tacomas & 96-2002 4Runners 2 01-12-2004 08:11 PM
headgasket TRunner 95.5-2004 Tacomas & 96-2002 4Runners 9 07-25-2003 01:23 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
