| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
Seven Times you fall, Eight times you get up |
#2 (permalink) |
I would go with the Engnbldr gasket set. I bought mine from the dealer and it cost a ton of coin. If you're really set on the Toyota head gasket, just get that from the dealer and still get the Engnbldr gasket set. The OEM Toyota gasket is only about $30, so you'd still be well under how much money the dealer wants. Local dealership here wanted $25 for the semicircular plugs that go on the head. I bought some aftermarket ones for $5. I ended spending close to $300 Cdn for my gaskets because I had to keep going back to the dealership for misc ones. I'll never do that again. The engnbldr set is only $60 and will have every gasket you could possibly need.
So a compression test and leak down test BEFORE you start tearing the engine apart. I only did a compression test and really wished I had also done a leak down test before I took the head off. Check your timing chain and guides while you're there with everything off. Also, maybe replace your timing cover ($30-40 from engnbldr IRRC). A tiny pinhole can cause a leak. Not sure where the fuel filter is on your 22R but it's buried on the 22RE, so you might want to replace that while you've got everything apart. Maybe new water pump and oil pump? Other than that, take the opportunity to flush out your cooling system. Also, it's way easier to do with the engine out of the truck and on a stand.
__________________
Black 89 4runner, 31'' BFG TA/KOs, Optima Red Top, DD with lots of rust... Black 89 YJ, SOA, 4'' lift springs, 35'' Procomp Xterrains, 4.2L, MC2100 swap, Optima Red Top, AX-15, SYE, MORE Traction bar, D30F/D44R/4.56/ - Aussie locked GO SENS!!! |
#3 (permalink) |
Any particular reason you're going with stealership gaskets? Their good gaskets, but you can get gasket kit's from Ted aswell, and they are very very complete, good quality and cost a hell of a lot less.
And I know there is a big debate about whether you need to or not, but new headbolts are never a bad idea. If you've got the intake manifold off anyways, this would be a good time to do the fuel filter. It's super easy to get at with everything out of the way as it will be. Make sure you've got oil, a filter and about a gallon of coolant. No matter how long you drain the cooling system, so always spills out when you yank the rad.
__________________
86 Turbo Pickup EB Street RV head EB 268 Cam V6 Brakes + MC A340F auto ---> W56 5-spd swap ...I want a bigger turbo... |
#4 (permalink) |
didnt see the gasket set on enginbldr, went lookin and found it thats about 1/2 what i can get them at the dealer for so, scrub the toyota gaskets
I will do the fuel filter overlooked that one. I allways replace the head bolts because i am paranoid and hate doing things twice.
__________________
#5 (permalink) |
How many miles do you have on your timing chain? Also, may want to consider dropping the oil pan as you'll probably end up dropping some stuff into it.
__________________
1985 pickup std cab 4wd rebuilt 2.4L 22r by Oregon Engine Rebuilders, RV cam, oversize valves, Weber 34 DGEC, 8k on engine,5 speed, OME shocks N93/N85 front/rear, rear diff breather, Durabak interior, Summit proportioning valve, SR5 cluster mod, 3" RB body lift, warn winch brushguard with harbor freight winch, custom rear bumper, FROR floating rear axle with pickup disc brakes all around |
| Tags |
| 22r, 22re, 86, change, cover, gasket, head, k746, replace, replacement, replacing, toyota, upgrades, valve, weber |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| who makes the best head gasket? 22r | cruisinforburgers | 86-95 Trucks & 4Runners | 11 | 08-03-2009 10:10 AM |
| 22r head gasket | deserttoy84 | The Classifieds GraveYard | 1 | 12-11-2007 12:11 AM |
| head gasket replacement | AKripper | 86-95 Trucks & 4Runners | 4 | 08-25-2006 07:48 AM |
| head gasket replacement | clint | 86-95 Trucks & 4Runners | 15 | 07-11-2006 02:46 PM |
| 22r head gasket qustion | dr3wstar | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 03-21-2005 08:18 PM |
