22R Carburettor - special screw?!? / gasket?
Hey guys,
after two weeks of waiting I finally got my carb-kit and tried to disassemble my carb today - not too successful tho.
I got two questions for you:
Number 1:
Which gasket am I supposed to use on which side of the placeholder? Please have a look on the pic:
Question 2:
How can I loosen this screw!?!? As you can see I wasn't too successful with my tools. I don't want to break it.
Thx for your answers :-)
Number 1:
Question 2:
when i rebuilt mine i had to let my carb soak in a tupperwear container of PB Blaster for a couple of days. be sure to use the right size screwdriver for the screw also. if it does continue to slip like that you can use a chisel to remove it and locate a new one somewhere. good luck
Oh ... thx for the picture - it helped a lot. I thought this would have been the idle mixture screw.
Do you now what the gizmo obove the idle screw is doing?
Nevertheless I don't know which gasket I should use for the placeholder - there was no gasket at all when I unscrewed the carby...help is highly appreciated...
Hmmm ... what does "soak" mean? Is 2-3 hours enough?
And: Do I have to get the jets out? It feels as they are superglued to the casing :-( ... Currently its just soaking in "as is".
Actually I am asking myself if this will help me for my problem. On the last two rides I had the engine stalled after when I rolled down a hill (without any pressure on the gas pedal) and stopped in front of a traffic light. I have the feeling that it also could be my EGR valve that probably is constantly open...that would also explain the rough idle I had recently. I will have a look on it tomorrow.
Any idea if it is possible to repair a faulty EGR valve? Don't have money to buy a new one :-(
Damn ... I assembled the carby today and my idle is still running like crap. I checked the EGR ... it is working fine.
I'm giving up and gonna sell my 4runner. The only thing I did not try yet is to install a new distributor cap and a new coil, but I don't have any time&money anymore in Australia.
One last thing:
Can anybody explain me the idle screw? I don't get it! The further I screw it inside, the richer the engine runs ... in my head it is the complete opposite way. When I screw something in, I would usually expect that I close a valve. Can anybody explain this?
One last thing:
