22r to 22rec ???
Old 06-16-2010, 02:33 PM
ebunker's Avatar
22r to 22rec ???
I put a "camper" cam in a 22r. Engine wise, does this install by itself constitute a conversion to a 22rec?
The reason I'm asking is that after the install of the "camper" cam, I failed the state emissions test... and I'm wondering what I might need to be doing differently with this new cam to get it to pass? The tech sheet from Comp Cam says I need .010 and .010 valve lashes... I'm wondering about if ignition timing needs to be change as well.
Thanks
-Ted
Old 06-16-2010, 02:38 PM
toyota4x4907's Avatar
No it does not. 22rec constitutes a California emissions 22re, which is an EFI 22r. Why you failed was probably because timing is off as is valve lash, making more exhaust than "acceptable" for wherever you are.
buckz6319
08-05-2017 03:50 AM
Iceman4193
10-16-2015 10:50 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
puddlepirate
09-29-2015 08:02 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: 22r to 22rec ???
