22r to 22re swap help
Old 08-20-2009, 03:07 PM
89_loyo's Avatar
i have an89 22re that threw a rob bearing. so i bought an 87 22r. when swappin the 212r to 22re do i need to put the 22re head on the 22r or will the 22r head work?
Old 08-20-2009, 05:01 PM
yoterr's Avatar
yeah you need the 22RE head to put it on the 22R the intake ports are different, as well as some other little stuff
Old 08-20-2009, 05:14 PM
89_loyo's Avatar
now i have been told by two dif ppl dif things i have had someone tell me it the 22r head will work can someone tell me the truth not sayiin any one is lying but i just need someone who knows for a fact
Old 08-20-2009, 06:52 PM
abecedarian's Avatar
85-up 22R and 22RE blocks and heads should be the same. However, the 22r was carbureted and has a mechanical fuel pump and as such has an eccentric lobe on the camshaft to drive the fuel pump whereas the 22re is injected so it has a block off plate where the fuel pump would go and there is a shim / washer on the end of the camshaft where the lobe for the fuel pump would be. You'll need to move the block-off plate from the 22re to the 22r and can change the shim for the eccentric if you'd like, but it shouldn't hurt anything to leave it.
I have successfully put an 88 22R in to a 91 22RE chassis and only had the above to deal with.
If the 22R is from before 85 (and possibly some 85's too), it may or may not be the same (likely not). There may be differences in exhaust port shapes and other subtle differences that make it difficult to correctly swap the old engine design into a newer chassis.
Old 08-20-2009, 07:34 PM
Plumbrbob's Avatar
the most noticable difference between the 81-84 22r and the 85-95 22r heads are the combustion chambers the early 22r uses dome top pistons and the later uses flat top pistons. so flip em over if the combustion chambers are the same shape your good to go.
85-95 22r heads and 22re heads are the same even the cams are identical
x2 with abe on the fuel pump issue
Old 08-21-2009, 08:18 AM
ool hand luke's Avatar
I'm looking at doing this same thing. will the 22re motor mount right up to pretty well everything on my 87 22r? and does it make a difference that the 22re is from a 2wd? thanks guys.
Old 08-21-2009, 08:24 AM
89_loyo's Avatar
i have a complete 22re thats an 89 and a complete 87 22r so have everything to do it. and if i did swtch heads how do i set the timing chain
Old 08-21-2009, 09:57 AM
The oil pickup and pan are different between 2wd and 4wd so those would have to be switched.
Beyond that, everything from power steering pump, alternator and a/c compressor to transmissions will bolt right up.
Old 08-21-2009, 10:00 AM
If the 22r has the same exhaust ports as the 22re and have no other reason to remove the head, I wouldn't bother swapping heads.
You can see the ports without disassembling the engine: just look at where the exhaust manifold bolts up. The ports should be 'pear' shaped:
Old 08-21-2009, 11:23 AM
89_loyo's Avatar
what if the 22r is from a 4wd and the 22re from a 2wd and the 22re is goin in the 2wd ?
Old 08-21-2009, 11:31 AM
Same difference.
To put an engine from a 2wd into a 4wd or vice-versa, you'd have to swap the oil pan and pickup tube from one to the other.
Engine: 2wd. Truck: 4wd- need oil pan and pick up tube from 4wd engine installed on 2wd engine.
Engine: 4wd. Truck: 2wd- need oil pan and pick up tube from 2wd engine installed on 4wd engine.
Engine: 2wd. Truck: 2wd- nothing to do with oil pan.
Engine: 4wd. Truck: 4wd- nothing to do with oil pan.
And there's no difference if the engine is from a truck or 4Runner, 22R or 22RE, the above still applies.
Old 08-21-2009, 11:58 AM
cool, so I would just take those off my 22r and put em on the re?
I dont have ac, so that part doesnt matter. thanks!
Old 09-13-2011, 08:10 PM
tstein1024's Avatar
Will an 87 22RE head bolt up to a 83-84 22R block? What is the earliest year the 22RE was produced?
Old 04-13-2012, 10:39 AM
techrized's Avatar
I swaped the running gear in my samurai to all 85 Toyota, axles, trans, transfercase,and 22r. It worked fantastic but the weber would stumble on step hills making it difficult in competition. I stole the EFI from a Buddys wrecked 91 celica. Everything bolted up perfect I have had some trouble mating the engine management harness to my custom harness I installed in the samurai. I need to no what fuel pressure I should be running I have a 55psi pump feeding it now. My main issue is it starts but only runs for a few seconds then shuts down it wont fire imeditly after it shuts down, if I wait a couple of minutes it will start but fall on its face. I cant get it running long enough to get it timed. Im kinda at a loss. Can anyone guide me to any one that has done a carb to EFI swap.
Old 01-15-2013, 01:48 PM
Strokedcoupe's Avatar
Are the intake ports the same on 22r ans 22re engines I bought a 22re intake to swap my 22r carb to efi and megasquirt this will bolt on my head coeerct?
Old 01-15-2013, 02:14 PM
Co_94_PU's Avatar
How to identify your engine 20r/22r/22re block and head
1980 and earlier have round intake, everything after that is square.
75-80 is round <=> round
81-84 is square <=> round
85+ is square <=> pear
Old 01-15-2013, 04:42 PM
Ok thanks mine is 85 so should be fine
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
deepmarsh
08-06-2015 03:44 AM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: 22r to 22re swap help
