22 RE stalls only when driving
Old 08-19-2013, 05:10 AM
tdpillo1's Avatar
94 22 RE 220k
22re stall only while driving
94 22RE 221k.
Trouble started over a month ago. Driving in the morning and after 5 minutes or so, I could feel it miss slightly, accelerating and decelerating. Didn't last long and didn't do it everyday. It has since progressed to full on stalling and running bad. I am good with an VOM and I set out to test O2 sensors and everything else that I could think. I can not replicate the issue under idle conditions which is making it VERY aggravating.
Though the bench test for the AFM passed perfectly, I had been thinking it could be that EXCEPT that, there are times that the truck will not start after a stall out. I will watch the tailpipe for smoke when it gives me trouble starting, looking for signs of flooding but, no black smoke is present. Fuel filter is a little under 2 years old. TPS won't pass bench tests but I would think if it were that, I'd be able to replicate the trouble while revving it in the driveway.
Tuned it up yesterday with plugs, cap & rotor and verified timing. Plugs were very white and I'd guess it's running lean. Would a faulty AFM give me lean fuel issues and trouble with fuel delivery on a startup?
Old 08-19-2013, 05:47 AM
SHINE RUNNER's Avatar
change fuel filter first. most likely the prob.also a vaccume leak will cause it to run lean.
Old 08-20-2013, 09:15 AM
Innocent Fool's Avatar
x2. Classic symptom of a plugged Fuel Filter
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
jasonty
41
12-23-2018 01:00 PM
kyletbert
07-17-2015 11:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 22 RE stalls only when driving
