.20 .30 .40 over ??? Any perks?
Old 02-09-2014, 09:57 AM
Yodalife12's Avatar
Any diffrence on the borading ? Hp ? Torque?
Also if you run a cam around .443 would it be best to run the dual valve springs ?
Thanks
Old 02-09-2014, 10:36 AM
Rule So Hard's Avatar
"Boring" your engine does increase displacement which does increase HP a very negligible amount. But its actually to restore your cylinders to roundness and a nice surface for rings to seal. As far as cams and springs. You want your springs stiff enough to close the valve as quickly as the cam lobe will allow at your maximum rpm. As lift and or duration increases the "steepness of the cam profile increases also. This means that if your springs are not stuff enough they will "float". This can cause all sorts of problems that can make your day not so fun.
Old 02-09-2014, 12:50 PM
wyoming9's Avatar
Red face
Bore only enough to get the cylinders round .
Material left to bore again in 1/2 million miles
Big Cam strong new springs to make sure the valves follow the cam
Kytowboater
09-17-2015 11:17 AM
pancake_ef2
06-09-2009 09:20 AM
rusche
09-26-2008 07:14 PM
Ava
14
08-27-2003 07:22 AM
Quick Reply: .20 .30 .40 over ??? Any perks?
