2 questions.
2 questions.
1) will a 4runner center console fit in a single cab truck with bucket seats? where is the best place to get a good used one at a good price.
2) how do i install a rear slider window?
to remove the window
get a flat screw driver and push the bottom seal from corner to corner from the inside to the outside. once the corners are out the window should come right out.
to install, get a long rope and install it around the window seal. put the remaining rope in the truck and have someone push the window from the outside toward the inside. slowly put the rope from the seal and make sure the seal is setting in the right position.
I'm not sure if the console will fit but if you get one from a 4Runner it will have holes in it where the rear wiper switch and rear window switch go. You'd probably be better off getting one from an xtra cab pickup since they won't have those holes.
I got a console for my '88 4x2 when I put bucket seats in it and it did not have any mounts for it, so I had to make some. I got mine out of a newer 4Runner and the size is good. They do have holes for the rear heater and an ashtray as mentioned above, but you can't really see them in a standard cab pickup.
kawazx636
10-06-2021 03:03 PM
defrag4
07-31-2015 10:50 AM
